RT-Smart 驱动程序开发
简单的驱动程序示例​
在讲解驱动框架等理论之前,本节先引入2个驱动程序让大家先有个概念。
Hello驱动程序示例​
  1. 添加drv_hello.c驱动程序
在“k230_sdk/src/big/rt_smart/kernel/rt-thread/components/drivers/misc”路径下新建drv_hello.c文件:
cd k230_sdk/src/big/rt_smart/kernel/rt-thread/components/drivers/misc
vim drv_hello.c
并将下面程序添加到drv_hello.c文件中:
* Copyright (c) 2006-2018, RT-Thread Development Team
* SPDX-License-Identifier: Apache-2.0
* Change Logs:
* Date Author Notes
* 2018-12-05 zylx first version
* 2018-12-12 greedyhao Porting for stm32f7xx
* 2019-02-01 yuneizhilin fix the stm32_adc_init function initialization issue
* 2024-12-02 100askteam add rt_size_t hello_read
#include<board.h>
#include<rtthread.h>
#include<rtdevice.h>
#include<string.h>
//#define DRV_DEBUG
#define LOG_TAG "drv.hello"
//#include <drv_log.h>
static struct rt_device hello_drv;
static rt_size_t hello_read(rt_device_t dev, rt_off_t pos, void *buffer, rt_size_t size)
// 简单地返回一个固定字符串到缓冲区
const char *response = "Hello from read!\n\r";
rt_size_t len = strlen(response);
// 确保不会超出缓冲区大小
if (size < len)
len = size;
// 复制字符串到缓冲区
memcpy(buffer, response, len);
return len;
static rt_size_t hello_write(rt_device_t dev, rt_off_t pos, const void *buffer, rt_size_t size)
const int *tmp = buffer;
if (tmp[0] == 1)
rt_kprintf("Hello, sam\n\r");
else if (tmp[0] == 0)
rt_kprintf("Bye, sam\n\r");
rt_kprintf("Invalid\n\r");
return size;
#ifdef RT_USING_DEVICE_OPS
const static struct rt_device_ops hello_ops =
RT_NULL,
RT_NULL,
RT_NULL,
hello_read,
hello_write,
RT_NULL,
static int hello_drv_init(void)
int ret;
/* 分配一个 rt_device */
/* 设置 */
hello_drv.type = RT_Device_Class_Miscellaneous;
hello_drv.rx_indicate = RT_NULL;
hello_drv.tx_complete = RT_NULL;
hello_drv.ops = &hello_ops;
#else
hello_drv.init = RT_NULL;
hello_drv.open = RT_NULL;
hello_drv.close = RT_NULL;
hello_drv.read = hello_read;
hello_drv.write = hello_write;
hello_drv.control = RT_NULL;
/* 注册 */
ret = rt_device_register(&hello_drv, "hello", RT_DEVICE_FLAG_RDWR);
rt_kprintf("rt_device_register hello, ret = %d\n", ret);
return ret;
INIT_BOARD_EXPORT(hello_drv_init);
添加完以后我们还要在misc目录下“SConscript”中添加drv_hello.c驱动:
src = src + ['drv_hello.c']
之后就可以编译、打包镜像,烧录到我们的板子上。
  1. 编译打包、烧录镜像
退回到“k230_sdk”路径下执行以下命令:
make CONF=k230_canmv_dongshanpi_defconfig
以上命令会编译dshanpi-canmv开发板配置,会编译生成相应配置的固件
进入到“k230_sdk/output/k230_canmv_dongshanpi_defconfig/images”路径下我们会看到此路径下有一个名为sysimage-sdcard.img 的镜像
K230 嵌入式 AI 全栈开发手册 - 122
将此镜像拷贝到windows中,并将此镜像使用镜像烧录软件烧录到SD卡中,SD卡镜像烧录方法见**“3.2.4SDK烧录章节”**;
烧录完成将SD卡插到开发板上,将拨码开关拨为off,off,SD卡启动,启动后我们进入到rt-smart大核中,查看是否有我们想要的hello驱动,如下图所示:
使用 “ls /dev” 查看:
K230 嵌入式 AI 全栈开发手册 - 123
这时我们已经成功添加了“hello”驱动,接下来就可以添加应用程序了。
  1. 添加drv_hello_test.c 应用程序
到k230_sdk/src/big/rt-smart/userapps目录下创建一个文件夹,命名为drv_hello_test:
cd k230_sdk/src/big/rt-smart/userapps
mkdir drv_hello_test
cd drv_hello_test
并创建以下三个文件:
  1. drv_hello_test.c:
#include <rtthread.h>
#include <rtdevice.h>
/* APP函数定义 */
int main(void)
rt_device_t dev;
char write_data = 1;
char read_data[20] = {0};
rt_size_t length;
/* 查找设备 */
dev = rt_device_find("hello");
if (dev == RT_NULL)
rt_kprintf("find device failed!\n");
/* 打开设备 */
if (rt_device_open(dev, RT_DEVICE_FLAG_RDWR) != RT_EOK)
rt_kprintf("open device failed!\n");
/* 向设备写入数据 */
if (rt_device_write(dev, 0, &write_data, sizeof(write_data)) != sizeof(write_data))
rt_kprintf("write to device failed!\n");
rt_device_close(dev);
/* 从设备读取数据 */
length = rt_device_read(dev, 0, read_data, sizeof(read_data) - 1);
if (length == 0)
rt_kprintf("read from device failed!\n");
/* 输出读取到的数据 */
read_data[length] = '\0';
rt_kprintf("Read from device: %s\n", read_data);
/* 关闭设备 */
MSH_CMD_EXPORT(main, sample for hello device);
  1. SConscript:
# RT-Thread building script for component
from building import *
cwd = GetCurrentDir()
src = Glob('*.c')
CPPPATH = [cwd]
CPPDEFINES = [
'HAVE_CCONFIG_H',
group = DefineGroup('drv_hello_test', src, depend=[''], CPPPATH=CPPPATH, CPPDEFINES=CPPDEFINES)
Return('group')
  1. SConstruct:
import os
import sys
# add building.py path
sys.path = sys.path + [os.path.join('..','..','tools')]
BuildApplication('drv_hello_test', 'SConscript', usr_root = '../')
之后回到k230_sdk/src/big/rt-smart/目录,配置环境变量:
进入k230_sdk/src/big/rt-smart/userapps目录,编译程序:
ubuntu@ubuntu2004:~/k230_sdk/src/big/rt-smart/userapps$ scons --directory=drv_hello_test
scons: Entering directory `/home/canaan/k230_sdk/src/big/rt-smart/userapps/drv_hello_test'
scons: Building targets ...
scons: building associated VariantDir targets: build/drv_hello_test
CC build/drv_hello_test/drv_hello_test.o
LINK drv_hello_test.elf
scons: done building targets.
编译好的程序在drv_hello_test文件夹下:
K230 嵌入式 AI 全栈开发手册 - 124
我们可以看到名为“drv_hello_test.elf”的可执行程序;
之后即可将drv_hello_test.elf使用ADBpush到小核linux的sharefs目录下,然后大核rt-smart的sharefs下也会出现该程序:
sudo abd push drv_hello_test.elf /sharefs
K230 嵌入式 AI 全栈开发手册 - 125
之后我们分别进入小核linux和大核rt-smart下的sharefs目录下分别查看是否有drv_hello_test.elf:
小核:
K230 嵌入式 AI 全栈开发手册 - 126
大核:
K230 嵌入式 AI 全栈开发手册 - 127
之后我们便可以在大核里直接运行drv_hello_test.elf:
K230 嵌入式 AI 全栈开发手册 - 128
注意:使用ADB的前提时提前安装ADB,详情请见**“3.4开发板文件传输”**章节!
LED驱动程序示例​
在“k230_sdk/src/big/rt_smart/kernel/rt-thread/components/drivers/misc”路径下新建drv_led.c文件:
vi drv_led.c
并将下面程序添加到drv_led.c文件中:
#include <board.h>
#include "ioremap.h"
#include "drv_gpio.h"
#include "drv_hardlock.h"
static struct rt_device led_drv;
static int hardlock;
static volatile uint32_t *g_gpio0_base_reg;
static rt_size_t led_read(rt_device_t dev, rt_off_t pos, void *buffer, rt_size_t size);
int *p = buffer;
int val = *(g_gpio0_base_reg+0) & (1<<20);
if (val)
val = 1;
val = 0;
p[0] = val;
return 4;
static rt_size_t led_write(rt_device_t dev, rt_off_t pos, const void *buffer, rt_size_t size);
// 根据写入的数据控制 LED 的开关
const char *cmd = (const char *)buffer;
if (strncmp(cmd, "on", 2) == 0)
//while(0 != kd_hardlock_lock(hardlock));
*(g_gpio0_base_reg+0) &= ~(1<<6);
//kd_hardlock_unlock(hardlock);
else if (strncmp(cmd, "off", 3) == 0)
*(g_gpio0_base_reg+0) |= (1<<6);
rt_kprintf("Invalid command\n");
return size;
// LED 驱动操作结构体
const static struct rt_device_ops led_ops =
RT_NULL,
RT_NULL,
RT_NULL,
RT_NULL,
led_write,
RT_NULL,
// LED 驱动初始化函数
static int led_drv_init(void)
int ret;
g_gpio0_base_reg = rt_ioremap(0x9140B000, 0x1000);
if (!g_gpio0_base_reg)
rt_kprintf("Failed to map GPIO registers\n");
return -RT_ERROR;
/* 配置为GPIO,output */
*(g_gpio0_base_reg+1) |= (1<<6);
/* 初始化 LED 设备结构体 */
led_drv.type = RT_Device_Class_Miscellaneous;
led_drv.rx_indicate = RT_NULL;
led_drv.tx_complete = RT_NULL;
led_drv.ops = &led_ops;
/* 注册 LED 设备 */
ret = rt_device_register(&led_drv, "led", RT_DEVICE_FLAG_RDWR);
rt_kprintf("rt_device_register led, ret = %d\n", ret);
return ret;
INIT_BOARD_EXPORT(led_drv_init);
src = src + ['drv_led.c']
之后就可以打包镜像,烧录到我们的板子上。
  1. 编译打包、烧录镜像
K230 嵌入式 AI 全栈开发手册 - 129
使用 “ls /dev” 查看:
K230 嵌入式 AI 全栈开发手册 - 130
这时我们已经成功添加了“led”驱动,接下来就可以添加应用程序了。
mkdir drv_led_test
cd drv_led_test
并创建以下三个文件:
  1. drv_led_test.c:
#include <string.h>
// LED 控制函数
static void led_control(const char *cmd)
struct rt_device *led_dev;
/* 查找LED设备 */
led_dev = rt_device_find("led");
if (led_dev == RT_NULL)
rt_kprintf("find led device failed!\n");
return;
/* 打开LED设备 */
if (rt_device_open(led_dev, RT_DEVICE_FLAG_RDWR) != RT_EOK)
rt_kprintf("open led device failed!\n");
return;
/* 写入命令到LED设备 */
if (strcmp(cmd, "on") == 0)
rt_device_write(led_dev, 0, "on", 2);
else if (strcmp(cmd, "off") == 0)
rt_device_write(led_dev, 0, "off", 3);
rt_kprintf("Invalid command: %s", cmd);
/* 关闭LED设备 */
rt_device_close(led_dev);
// 主函数
if (argc != 2)
rt_kprintf("Usage: %s <on/off>\n", argv[0]);
led_control(argv[1]);
  1. SConscript:
src = Glob('*.c')
CPPPATH = [cwd]
CPPDEFINES = [
'HAVE_CCONFIG_H',
Return('group')
  1. SConstruct:
import os
import sys
BuildApplication('drv_led_test', 'SConscript', usr_root = '../')
ubuntu@ubuntu2004:~/k230_sdk/src/big/rt-smart/userapps$ scons --directory=drv_led_test
scons: Entering directory `/home/ubuntu/k230_sdk/src/big/rt-smart/userapps/drv_led_test'
scons: building associated VariantDir targets: build/drv_led_test
CC build/drv_led_test/drv_led_test.o
LINK drv_led_test.elf
/home/ubuntu/k230_sdk/toolchain/riscv64-linux-musleabi_for_x86_64-pc-linux-gnu/bin/../lib/gcc/riscv64-unknown-linux-musl/12.0.1/../../../../riscv64-unknown-linux-musl/bin/ld: warning: drv_led_test.elf has a LOAD segment with RWX permissions
编译好的程序在drv_led_test文件夹下:
K230 嵌入式 AI 全栈开发手册 - 131
K230 嵌入式 AI 全栈开发手册 - 132
这时我们还没有完成对led 的配置,led是使用的引脚是GPIO6,但是在“k230_canmv_dongshanpi.dts”的iomux中的GPIO6默认的配置为JTAG功能,所以我们要将GPIO6更改为GPIO功能;
cd k230_sdk/src/little/uboot/arch/riscv/dts
vi k230_canmv_dongshanpi.dts
(IO6 ) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 4<<DS | 1<<ST )
K230 嵌入式 AI 全栈开发手册 - 133
之后在重新参照“2.编译打包、烧录镜像”,重新编译,烧录镜像。
烧录完成启动开发板分别进入小核linux和大核rt-smart下的sharefs目录下分别查看是否有drv_hello_test.elf:
小核:
K230 嵌入式 AI 全栈开发手册 - 134
大核:
K230 嵌入式 AI 全栈开发手册 - 135
之后我们便可以在大核里直接运行drv_hello_test.elf on/off控制led灯的亮灭了:
K230 嵌入式 AI 全栈开发手册 - 136
I/O设备驱动​
I/O设备模型与分类​
RT-Thread中,就是引入了驱动框架层,实现了各类UART驱动的统一、实现了各类I2C控制器驱动的统一、实现了各类SPI控制器驱动的统一,等等。I/O设备模型如下图所示:
K230 嵌入式 AI 全栈开发手册 - 137
以上一节的hello驱动为例,hello_frame_drv.c驱动框架层里调用的“rt_device_register”就是在“I/O设备管理层”实现的。“I/O设备管理层”起到承上启下的作用:下面具体的驱动程序调用“rt_device_register”把驱动程序注册进某个链表。上层应用程序使用“rt_device_find”在这个链表里找到驱动程序,然后调用“rt_device_open/read/write”等函数使用驱动程序。
设备驱动框架层,类似hello_frame_drv.c,它提供了xxx_register函数,比如“register_hello_dev”、“rt_hw_serial_register”、“rt_spi_bus_register”,这些函数会设置rt_device结构体,给它提供事先写好的各类接口函数,然后调用“rt_device_register”注册驱动。
谁来调用设备驱动框架层的“xxx_register”函数?底下的设备驱动层,比如hello_sam.c。设备驱动层的代码,实现了具体设备的操作,然后调用设备驱动框架层提供的“xxx_register”函数来注册驱动。
RT-Thread驱动的核心,是rt_devcie结构体。即使使用各种“设备驱动框架层”,它最终也是构造、注册一个rt_device结构体。这个结构体中,有一个type成员,如下:
struct rt_device
struct rt_object parent; /**< inherit from rt_object */
enum rt_device_class_type type; /**< device type */
它的取值有这些,表示各类驱动程序:
RT_Device_Class_Char = 0, /**< character device */
RT_Device_Class_Block, /**< block device */
RT_Device_Class_NetIf, /**< net interface */
RT_Device_Class_MTD, /**< memory device */
RT_Device_Class_CAN, /**< CAN device */
RT_Device_Class_RTC, /**< RTC device */
RT_Device_Class_Sound, /**< Sound device */
RT_Device_Class_Graphic, /**< Graphic device */
RT_Device_Class_I2CBUS, /**< I2C bus device */
RT_Device_Class_USBDevice, /**< USB slave device */
RT_Device_Class_USBHost, /**< USB host bus */
RT_Device_Class_SPIBUS, /**< SPI bus device */
RT_Device_Class_SPIDevice, /**< SPI device */
RT_Device_Class_SDIO, /**< SDIO bus device */
RT_Device_Class_PM, /**< PM pseudo device */
RT_Device_Class_Pipe, /**< Pipe device */
RT_Device_Class_Portal, /**< Portal device */
RT_Device_Class_Timer, /**< Timer device */
RT_Device_Class_Miscellaneous, /**< Miscellaneous device */
RT_Device_Class_Sensor, /**< Sensor device */
RT_Device_Class_Touch, /**< Touch device */
RT_Device_Class_PHY, /**< PHY device */
RT_Device_Class_Unknown /**< unknown device */
I/O设备管理接口​
1. 驱动程序使用的接口
驱动程序使用“rt_device_create/rt_device_destroy”来分配、销毁rt_device结构体,使用“rt_device_register/rt_device_unregister”来注册、反注册rt_device。这些函数的接口定义如下:
rt_device_t rt_device_create(int type, int attach_size);
void rt_device_destroy(rt_device_t dev);
rt_err_t rt_device_register(rt_device_t dev,
const char *name,
rt_uint16_t flags);
rt_err_t rt_device_unregister(rt_device_t dev);
rt_device_create函数用来分配一个rt_device结构体,它的参数和返回值入下表所示:
输入参数功能描述
type设备类型,取值为enum rt_device_class_type的值
attach_size额外的空间,要分配的空间大小=rt_device结构体的大小+attach_size
返回值功能描述
rt_device_t线程创建成功,返回rt_device的指针
RT_NULL分配rt_device创建失败
rt_device_destroy函数用来销毁rt_device结构体,它的参数和返回值入下表所示:
输入参数功能描述
devrt_devcie_t类型,即rt_device指针,表示要销毁的rt_device
返回值无
rt_device_register函数用来注册一个rt_device结构体,它的参数和返回值入下表所示:
输入参数功能描述
devrt_devcie_t类型,即rt_device指针,表示要注册的rt_device
name设备的名字,以后可以根据名字找到这个设备
flags表示设备的属性,可取的值见后面
返回值功能描述
RT_EOK成功
其他值失败
flags能取的值如下:
* device flags defitions
#define RT_DEVICE_FLAG_DEACTIVATE 0x000 /**< device is not not initialized */
#define RT_DEVICE_FLAG_RDONLY 0x001 /**< read only */
#define RT_DEVICE_FLAG_WRONLY 0x002 /**< write only */
#define RT_DEVICE_FLAG_RDWR 0x003 /**< read and write */
#define RT_DEVICE_FLAG_REMOVABLE 0x004 /**< removable device */
#define RT_DEVICE_FLAG_STANDALONE 0x008 /**< standalone device */
#define RT_DEVICE_FLAG_ACTIVATED 0x010 /**< device is activated */
#define RT_DEVICE_FLAG_SUSPENDED 0x020 /**< device is suspended */
#define RT_DEVICE_FLAG_STREAM 0x040 /**< stream mode */
#define RT_DEVICE_FLAG_INT_RX 0x100 /**< INT mode on Rx */
#define RT_DEVICE_FLAG_DMA_RX 0x200 /**< DMA mode on Rx */
#define RT_DEVICE_FLAG_INT_TX 0x400 /**< INT mode on Tx */
#define RT_DEVICE_FLAG_DMA_TX 0x800 /**< DMA mode on Tx */
rt_device_unregister函数用来反注册一个rt_device结构体,它的参数和返回值入下表所示:
输入参数功能描述
返回值功能描述
RT_EOK成功(必定成功)
2. 应用程序使用的接口
应用程序先使用“rt_device_find”找到驱动程序,然后使用“rt_device_open”打开设备(第1次打开时,内部会调用rt_device_init函数来初始化设备,应用程序无需自己调用rt_device_init函数);接着,就可以调用“rt_devcice_control/rt_device_read/rt_device_write”来控制、读、写设备了;最后,不再使用这个设备时,就可以调用“rt_device_close”来关闭它。
这些函数的原型如下:
rt_device_t rt_device_find(const char *name);
rt_err_t rt_device_open(rt_device_t dev, rt_uint16_t oflag);
rt_err_t rt_device_close(rt_device_t dev);
rt_err_t rt_device_init(rt_device_t dev);
rt_err_t rt_device_control(rt_device_t dev, int cmd, void *arg);
rt_size_t rt_device_read(rt_device_t dev,
rt_off_t pos,
void *buffer,
rt_size_t size);
rt_size_t rt_device_write(rt_device_t dev,
rt_off_t pos,
const void *buffer,
rt_size_t size);
rt_device_find函数用来寻找rt_device结构体,它的参数和返回值入下表所示:
输入参数功能描述
name设备的名字,根据名字找到这个设备
返回值功能描述
rt_device_t成功,返回rt_device的指针
RT_NULL失败
rt_device_open函数用来打开设备,它的参数和返回值入下表所示:
输入参数功能描述
dev要打开的设备
oflag打开设备的flag
返回值功能描述
RT_EOK成功
其他负值失败
rt_device_init函数用来初始化设备,它是被rt_device_open调用的,它的参数和返回值入下表所示:
输入参数功能描述
dev要初始化的设备
返回值功能描述
RT_EOK成功
其他负值失败
rt_device_control函数用来控制设备,它的参数和返回值入下表所示:
输入参数功能描述
dev要控制的设备
cmd这是一个宏,一个数字,用来表示“控制什么”,它的取值是驱动程序决定的
arg这是输入或输出参数,由cmd决定
返回值功能描述
RT_EOK成功
其他负值失败
rt_device_read函数用来读设备,它的参数和返回值入下表所示:
输入参数功能描述
dev要读的设备
pos偏移地址
size要读取的字节数
输出参数功能描述
buffer缓冲区,用来保存读到的数据
返回值功能描述
读取到的数据的个数(单位:字节)
rt_device_write函数用来写设备,它的参数和返回值入下表所示:
输入参数功能描述
dev要读的设备
pos偏移地址
buffer缓冲区,用来保存要写给设备的数据
size要写出去的数据的字节数
返回值功能描述
真正写到设备的数据的个数(单位:字节)
rt_device_close函数用来关闭设备,它的参数和返回值入下表所示:
输入参数功能描述
dev要关闭的设备
返回值功能描述
RT_EOK成功
其他负值失败
驱动编写流程与规范​
编写驱动程序时,有2种方法:
① 直接构造、注册rt_device
② 使用设备驱动框架层。
1. 直接构造、注册rt_device
流程为:分配、设置、注册rt_device结构体。分配rt_device结构体时,可以定义一个全局变量,也可以使用rt_device_create函数用来分配。设置rt_device结构体时,根据需要设置它的init/open/control/read/write/close成员,无需全部设置。最后,使用rt_device_register注册,提供的名字必须是唯一的。
2. 使用设备驱动框架层
需要根据具体的设备驱动框架层,分配、设置、注册具体的结构体。以UART驱动为例,要分配一个rt_serial_device结构体,设置它的时候,要提供配置信息、操作函数(rt_uart_ops结构体),最后使用rt_hw_serial_register函数注册。
示例代码如下:
K230 嵌入式 AI 全栈开发手册 - 138
3. 驱动程序编程规范
驱动程序是给应用开发人员使用,要避免暴露复杂的硬件操作细节,力求让没有硬件知识的人也知道如何使用驱动程序。
驱动程序要屏蔽不同硬件的差异,编写一个新的驱动程序时,要考虑可扩展性,力求能支持同类、不同型号的硬件。
驱动程序分层​
使用驱动程序的目的,是给上层应用程序提供统一的接口,比如都使用“rt_deivce_init/rt_device_open/rt_device_read/rt_device_write”等固定的函数来访问硬件,如下图:
K230 嵌入式 AI 全栈开发手册 - 139
怎么实现驱动程序呢?构造一个rt_device结构体,填充里面的init、open、close等成员,然后注册它。以drv_hello.c驱动为例,它的代码如下:
25 static rt_size_t hello_write(rt_device_t dev, rt_off_t pos, const void *buffer, rt_size_t size)
26 {
27 if (buffer[0] == 1)
28 rt_kprintf("Hello, sam\n\r");
29 else if (buffer[0] == 0)
30 rt_kprintf("Bye, sam\n\r");
31 else
32 rt_kprintf("Invalid\n\r");
33 return size;
34 }
/* 省略 */
48 static int hello_drv_init(void)
49 {
50 int ret;
51
52 /* 分配一个 rt_device */
53 /* 设置 */
54 hello_drv.type = RT_Device_Class_Miscellaneous;
55 hello_drv.rx_indicate = RT_NULL;
56 hello_drv.tx_complete = RT_NULL;
57
58 #ifdef RT_USING_DEVICE_OPS
59 hello_drv.ops = &hello_ops;
60 #else
61 hello_drv.init = RT_NULL;
62 hello_drv.open = RT_NULL;
63 hello_drv.close = RT_NULL;
64 hello_drv.read = RT_NULL;
65 hello_drv.write = hello_write;
66 hello_drv.control = RT_NULL;
67 #endif
68
69 /* 注册 */
70 ret = rt_device_register(&hello_drv, "hello", RT_DEVICE_FLAG_RDWR);
71 rt_kprintf("rt_device_register hello, ret = %d\n", ret);
72
73
74 return ret;
75 }
76 INIT_BOARD_EXPORT(hello_drv_init);
77
第25~34行实现了一个hello_write函数。
第65行,设置了rt_device结构体,它的write成员设置为hello_write函数。
第70行注册这个rt_device结构体。
以后,应用程序就可以如下使用这个驱动程序:
char buf[1];
rt_device_t hello_dev;
hello_dev = rt_device_find("hello");
rt_device_open(hello_dev, RT_DEVICE_OFLAG_RDWR);
buf[0] = 1;
rt_device_write(hello_dev, 0, buf, 1);
运行上面的代码,串口就会打印出“Hello,sam”。
但是,还不够:除了接口函数统一之外,还想把这些接口函数的参数类型也统一起来。比如还想实现另一个驱动程序,比如“hello2”驱动程序,希望应用程序调用rt_device_write时,传入的buf中,数值也只能是1或0才有效。怎么规定驱动程序只接收1或0,发现是其他数值就报错?当然可以编写文档来约束驱动开发人员:你必须按照文档来实现驱动。但是也许驱动开发人员根本没看到这个文档。RT-Thread的做法是引入设备驱动框架层,比如引入hello驱动框架层hello_frame_drv.c。
先在hello_frame_drv.h里定义一个新的结构体,代码如下:
24 struct hello_dev {
25 struct rt_device parent;
26 char *name;
27 };
28
29 int register_hello_dev(struct hello_dev *dev);
第24行定义了一个hello_dev类型,它的第1项必须是struct rt_device(第25行),其他的内容(第26行)就是自定义的内容。
然后,在hello_drame_drv.c里,实现一个register_hello_dev函数,代码如下:
23 static rt_size_t hello_write(rt_device_t dev, rt_off_t pos, const void *buffer, rt_size_t size)
24 {
25 struct hello_dev *hello_dev = (struct hello_dev *)dev;
26 if (buffer[0] == 1)
27 rt_kprintf("Hello, %s\n\r", hello_dev->name);
28 else if (buffer[0] == 0)
29 rt_kprintf("Bye, %s\n\r", hello_dev->name);
30 else
31 rt_kprintf("Invalid\n\r");
32 return size;
33 }
/* 省略 */
47 int register_hello_dev(struct hello_dev *dev)
48 {
49 int ret;
50
51 /* 设置 */
52
53 dev->parent.type = RT_Device_Class_Miscellaneous;
54 dev->parent.rx_indicate = RT_NULL;
55 dev->parent.tx_complete = RT_NULL;
56
57 #ifdef RT_USING_DEVICE_OPS
58 dev->parent.ops = &hello_ops;
59 #else
60 dev->parent.init = RT_NULL;
61 dev->parent.open = RT_NULL;
62 dev->parent.close = RT_NULL;
63 dev->parent.read = RT_NULL;
64 dev->parent.write = hello_write;
65 dev->parent.control = RT_NULL;
66 #endif
67
68 /* 注册 */
69 ret = rt_device_register(&dev->parent, dev->name, RT_DEVICE_FLAG_RDWR);
70 rt_kprintf("rt_device_register %s, ret = %d\n", dev->name, ret);
71
72 return ret;
73 }
在第47行的register_hello_dev函数中,初始化了rt_device结构体(第53~66行),里面使用的都是预先实现的、固定的函数,比如第64行的hello_write。这就把驱动程序的参数统一起来了:应用程序最终调用到驱动的hello_write时,hello_write里面保证了buf中数据必须是1或0才是正确的。
最后,谁来调用hello_drame_drv.c里的register_hello_dev函数?可以是hello_sam.c,也可以是hello_bill.c,比如:
17 #include "hello_frame_drv.h"
18
19 static struct hello_dev sam = {
20 .name = "sam",
21 };
22
23 static int hello_sam_init(void)
24 {
25 return register_hello_dev(&sam);
26 }
27 INIT_BOARD_EXPORT(hello_sam_init);
有了hello驱动框架层hello_frame_drv.c后,编写具体的驱动程序反而简单了:只需要定义一个hello_dev结构体(第19行),然后注册它即可(第25行)。
应用程序去使用hello_sam.c驱动程序时,代码如下(接口函数、参数没有变化):
char buf[1];
hello_dev = rt_device_find("sam");
buf[0] = 1;
从这个例子里,可以看到hello驱动的框架为(设备管理层源码为在rt-thread\src\device.c里,它实现了rt_device_register等函数,用来管理驱动):
K230 嵌入式 AI 全栈开发手册 - 140
